Einleitung
Thrustmaster sells spare parts on their online shop website.
You can also contact Thrustmaster technical support to obtain a replacement part if it is not available in your region.
Was du brauchst
Remove 4 screws highlighted on the first picture.
Unplug the white connector highlighted in the second picture.
Remove 2 screws highlighted in 3rd picture.
Remove the metal ring around the DIN connector.
Apply some glue around the DIN connector.
To reassemble your device, follow the instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
100%
Hier starten ›
