Zum Hauptinhalt wechseln
Fender Frontman 15r Power Switch Replacement
Was du brauchst
  1. Fender Frontman 15r Power Switch Replacement, Back panel: Schritt 1, Bild 1 von 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Power Switch Replacement: Schritt 3, Bild 1 von 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Power Switch Replacement, Mounting Bracket: Schritt 4, Bild 1 von 2 Fender Frontman 15r Power Switch Replacement, Mounting Bracket: Schritt 4, Bild 2 von 2
    • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  5. Fender Frontman 15r Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  6. Fender Frontman 15r Power Switch Replacement: Schritt 6, Bild 1 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 6, Bild 2 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  7. Fender Frontman 15r Power Switch Replacement: Schritt 7, Bild 1 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 7, Bild 2 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 7, Bild 3 von 3
    • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
  8. Fender Frontman 15r Power Switch Replacement, Power Switch: Schritt 8, Bild 1 von 2 Fender Frontman 15r Power Switch Replacement, Power Switch: Schritt 8, Bild 2 von 2
    • Mark, make note of, or remember the arrangement of the wires.
    • Remove the four female disconnected terminals from the switch terminals.
  9. Fender Frontman 15r Power Switch Replacement: Schritt 9, Bild 1 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 9, Bild 2 von 3 Fender Frontman 15r Power Switch Replacement: Schritt 9, Bild 3 von 3
    • Using the flat end of a spudger, push in one of the wedged locking clips.
    • Partially tilt the switch box so that clip is held down.
    • Repeat for the other side of the switch
  10. Fender Frontman 15r Power Switch Replacement: Schritt 10, Bild 1 von 2 Fender Frontman 15r Power Switch Replacement: Schritt 10, Bild 2 von 2
    • Be sure that both locking clips are pressed through the opening. This may take a few tries.
    • Gently remove the switch.
Abschluss
Once the old power switch is removed, install the new one by following the guide in reverse.
Eine weitere Person hat diese Anleitung absolviert.
Greg Sawers
91 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 24-30, Regan Fall 2012 Mitglied von Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 8,104
