Zum Hauptinhalt wechseln
Einleitung
There are many different styles of tuners and bridges, therefore, many different methods of removing the strings. This Starcaster has a string-through bridge and standard in-line tuners, so the string changing process is fairly simple.
Ersatzteile
  1. Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension. Repeat this for all six strings on the guitar. Repeat this for all six strings on the guitar.
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Be mindful of the string ends. They may be sharp and could puncture your skin. It may be necessary to use pliers to remove string ends from the tuning peg.
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
Christopher Hartigan
149 Reputation
5 Anleitungen geschrieben
Pasco Hernando, Team 5-3, Prince Fall 2014 Mitglied von Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,310
