Einleitung
Simple step-by-step instructions to replace the Refrigerator Water Filter Head & Tube Assembly WR17X12203.
Was du brauchst
Disconnect the electric plug from the wall.
Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
Use a little bucket to receive the water from the water lines.
Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
Pull up the gum seal compound.
Remove the 2 screws on top of the housing using 7 mm nut driver.
Pull the housing and filter out slowly.
Remove the filter by turn it counterclockwise
