Zum Hauptinhalt wechseln
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
Was du brauchst
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: Schritt 1, Bild 1 von 1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 2, Bild 1 von 1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 3, Bild 1 von 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 3, Bild 2 von 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 3, Bild 3 von 3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 4, Bild 1 von 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 4, Bild 2 von 2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 5, Bild 1 von 1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 6, Bild 1 von 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 6, Bild 2 von 2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 7, Bild 1 von 1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 8, Bild 1 von 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: Schritt 8, Bild 2 von 2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Abschluss
Giancarlo Marruffo
2 Reputation
1 Anleitung geschrieben
Pasco Hernando, Team 5-1, Prince Fall 2016 Mitglied von Pasco Hernando, Team 5-1, Prince Fall 2016
PHSC-PRINCE-F16S5G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 2,160
