Einleitung
This FastFix is provided so that you may be able to replace a broken FirsTime Wall Clock due to a faulty movement mechanism. This is helpful so you won’t have to spend money on replacing this item. It is a short and easy fix!
Was du brauchst
Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
Turn the display face up.
Use needle nose pliers to pull off the 'second' hand.
Use needle nose pliers to remove the 'minute' hand.
Then use needle nose pliers to remove the 'hour' hand.
Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
Now you may remove the display of the clock from your malfunctioning movement mechanism.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Is there a you tube showing these steps?
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Excellent illustrations!!!
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
