Einleitung
Clean and remove damaged batteries that may have leaked caustic or harmful substances.
Was du brauchst
Place the amplifier face-down and lift the cartridge lid up.
Remove the corroded battery with the assistance of the Spudger and place the battery in the plastic bag.
Close the lid of the battery cartridge and begin to unscrew the two 13mm screws located at the top and bottom of the battery cartridge with the Phillips #0 Screwdriver.
Use the Spudger to pry the battery cartridge away from the center console.
Dab one end of the Q-tip into the vinegar solution.
Rub the inside and outside of the battery cartridge as well as the battery terminal with the Q-tip to remove any acid residue. Use as many Q-tips needed to remove the acid.
Once finished place the used Q-tip(s) inside the small bag with the battery and dispose of the two properly.
All done! Return the cartridge back into the center console and screw in the two 13mm screws.
