Einleitung
This guide will show you how to remove and replace a blown speaker. Doing this will require a phillips head screwdriver and wire cutters. A soldering tool will also be needed to reattach wires to the new speaker.
Was du brauchst
Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
Once screws are removed, lift the panel from the amplifier and feed the battery terminals through holes in battery cartridges.
Take the panel off and set it to the side.
Use a Phillips #0 screwdriver to remove the four 25mm screws that fasten the speaker to the inside of the amplifier.
Desolder the black and white speaker wires from the contact board.
The speaker can now be completely removed from the amplifer.
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
