Was du brauchst
Depin outside pins on the original sensor. Use the sharp point of an exacto tool or similar.
Gently, bend the detent back out at a slight angle so it catches when re-inserted.
Detent shown at a slight angle so it catches when re-inserted.
Wires should be twisted with outer 2 wires swapped.
Use included m3x16 SHCS to attach new sensor.
Navigate from the display to Configuration>Advanced>Filament>Runout Mode
While hovering over Sensor Low, press the knob.
Navigate to Configuration>Store Settings and press the knob. You'll hear a confirmation beep.
3 weitere Personen haben diese Anleitung absolviert.
