Zum Hauptinhalt wechseln
Fitbit Alta HR Battery Replacement
Was du brauchst
  1. Fitbit Alta HR Battery Replacement, Remove straps: Schritt 1, Bild 1 von 2 Fitbit Alta HR Battery Replacement, Remove straps: Schritt 1, Bild 2 von 2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: Schritt 2, Bild 1 von 1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: Schritt 3, Bild 1 von 1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: Schritt 4, Bild 1 von 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: Schritt 5, Bild 1 von 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: Schritt 6, Bild 1 von 2 Fitbit Alta HR Battery Replacement, Lift motherboard: Schritt 6, Bild 2 von 2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: Schritt 7, Bild 1 von 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Wendy Sato
229 Reputation
1 Anleitung geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 83
Insgesamt: 1,719
