Einleitung
Has your Fitbit Charge HR stopped vibrating? Perhaps your Fitbit vibration motor has gone bad. This guide is a tear-down of the Fitbit Charge HR demonstrating how to replace the Vibration Motor for the Fitbit Charge HR.
Was du brauchst
Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
Remove the back cover from the device.
Remove the two 2.9 mm Torx screws holding the circuit board in place.
Carefully pry the board out using an opening tool.
Locate the vibration motor on the motherboard.
Desolder the red and black wires connected to the motherboard from the vibration motor.
Replace with new vibration motor.
