Einleitung
This guide will show you how to remove and replace your worn out or damaged wristbands.
Was du brauchst
Locate the metal pin behind the wristband located on the edge of metal ring.
Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
Remove wristband.
Fast fertig!
Abschluss
