Einleitung
This guide will show you the process of replacing the wrist strap of your Fitbit Inspire 2. Your fitness journey just got a boost as you take control of personalizing and maintaining your Fitbit device with confidence.
After years of use, sweat, grime, and oils will wear out the wrist strap on your Fitbit Inspire 2. You can always clean the strap, but if has started to tear or it's too loose, follow this guide and you'll have a secure wrist band in no time!
Whether you're looking to upgrade your Fitbit Inspire 2 with a stylish new strap or addressing a functional issue in your current one, this step-by-step guide is crafted to empower you throughout the replacement process. The wrist strap is not just a functional element; it's a reflection of your style and commitment to a healthy lifestyle. By understanding and mastering the replacement process, you not only enhance the aesthetics of your Fitbit but also ensure the longevity of your device.
Was du brauchst
Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
As you pull back the release lever, shift the strap diagonally.
Remove from the Fitbit strap.
Repeat the process for the other strap.
Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
Slide the replacement straps into the given slot and the lever will click back into place.
2 weitere Personen haben diese Anleitung absolviert.
