Zum Hauptinhalt wechseln
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Was du brauchst
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 1, Bild 1 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 1, Bild 2 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 1, Bild 3 von 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 2, Bild 1 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 2, Bild 2 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 2, Bild 3 von 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 3, Bild 1 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 3, Bild 2 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 3, Bild 3 von 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 4, Bild 1 von 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 5, Bild 1 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 5, Bild 2 von 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 5, Bild 3 von 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 6, Bild 1 von 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 6, Bild 2 von 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 7, Bild 1 von 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 7, Bild 2 von 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: Schritt 8, Bild 1 von 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emmanuel Emedeke
184 Reputation
1 Anleitung geschrieben
York University, Team S2-G6, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G6, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G6
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 62
Insgesamt: 4,995
