Einleitung
If the device cannot charge and is boot-looping, it is possible to force it to charge correctly by unplugging screen and speaker.
Was du brauchst
Remove the front panel
The panel is simply clipped and can be declipped easily by using a mediator as lever
The toy is closed by 5 Philips-head screws, size 0
Unscrew them all and open the product
The white piece is held by 4 Philips-head screws
Unscrew the three screws you can already access
Unscrew the selfie camera, held by two smaller screws
Under the camera, unscrew the forth screw holding the piece
Remove the glue around the screen connector
Disconnect by lifting the connector clip upward
The board is held by the 4 previously removed screws, plus another screw close to USB connector
Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
Princeton Technology PT5139-HT motor driver
Syncrown PT48D 2-inch thermal printer
Thinksum 123050 7.4V 750mAh li-ion battery
Screen, speaker, two photo modules
Once the toy is disassembled, replug the battery only and let it charge, with a micro-USB cable
Unplug the battery once again before remounting the device
To reassemble your device, follow the unmounting instructions in reverse order.
100%
Eve Redero hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
