Zum Hauptinhalt wechseln
Fixed Gear Bike Chainring Replacement
Was du brauchst
  1. Fixed Gear Bike Chainring Replacement, Chainring: Schritt 1, Bild 1 von 2 Fixed Gear Bike Chainring Replacement, Chainring: Schritt 1, Bild 2 von 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: Schritt 2, Bild 1 von 2 Fixed Gear Bike Chainring Replacement: Schritt 2, Bild 2 von 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: Schritt 3, Bild 1 von 2 Fixed Gear Bike Chainring Replacement: Schritt 3, Bild 2 von 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: Schritt 4, Bild 1 von 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: Schritt 5, Bild 1 von 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Ziellinie
aljndro__
121 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Mitglied von CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 263
