Zum Hauptinhalt wechseln
Fixing Epson Stylus Photo 1400 Paper Jam
  1. Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 1, Bild 1 von 2 Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 1, Bild 2 von 2
    • The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise.
    • Press paper button to eject paper.
    • If previous step does not work, turn off the printer and proceed to step 2. Else, proceed to step 4.
  2. Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 2, Bild 1 von 1
    • Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Pull the paper as straight as possible.
    • If this does not work, proceed to step 3. Else, proceed to step 4.
  3. Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 3, Bild 1 von 3 Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 3, Bild 2 von 3 Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 3, Bild 3 von 3
    • Open cover of the printer.
    • Gently pull out the paper through the hatch.
    • If ink cartridge is in the way, gently push it off to the side.
    • Close cover.
  4. Fixing Epson Stylus Photo 1400 Paper Jam: Schritt 4, Bild 1 von 1
    • If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 2 or 3, turn on printer and press paper button.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Xin Chen
1.105 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-11, Regan Fall 2011 Mitglied von Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
nkumbu namukoko - Antwort
My machine is Epson 1500w ,it make an unusual noise when printing to the middle of the paper and stop lwith the red light blinkinig. Please I need heklp
stephen Banguu-Wobnyine - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 6,905
