Zum Hauptinhalt wechseln
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
Was du brauchst
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 1, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 1, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 1, Bild 3 von 3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 2, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 2, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 2, Bild 3 von 3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 3, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 3, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 4, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 4, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 4, Bild 3 von 3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 5, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 5, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 5, Bild 3 von 3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 6, Bild 1 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 6, Bild 2 von 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: Schritt 6, Bild 3 von 3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
Abschluss
Kaitlyn Abrams
1 Reputation
1 Anleitung geschrieben
University of Maine, Team 2-1, Diaz Fall 2016 Mitglied von University of Maine, Team 2-1, Diaz Fall 2016
UMAINE-DIAZ-F16S2G1
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 799
