Zum Hauptinhalt wechseln
Fixing a Small Animal Cage Ladder
Was du brauchst
  1. Fixing a Small Animal Cage Ladder, Replacing the Rope for a Small Animal Cage Ladder: Schritt 1, Bild 1 von 1
    • Take your ladder out of the pet’s cage and lay it out to clearly assess the damage.
  2. Fixing a Small Animal Cage Ladder: Schritt 2, Bild 1 von 3 Fixing a Small Animal Cage Ladder: Schritt 2, Bild 2 von 3 Fixing a Small Animal Cage Ladder: Schritt 2, Bild 3 von 3
    • Gather your supplies for the fix (ie: new rope, scissors, ruler, sewing kit, clips). These items will be used to fix the small ladder.
  3. Fixing a Small Animal Cage Ladder: Schritt 3, Bild 1 von 2 Fixing a Small Animal Cage Ladder: Schritt 3, Bild 2 von 2
    • Cut the old rope in the ladder with scissors and pull it out of the cylindrical wood pieces.
    • Make sure the knots at the ends of the rope are cut. This will enable you to pull the rope out easily.
  4. Fixing a Small Animal Cage Ladder: Schritt 4, Bild 1 von 1
    • Measure your new rope to the length of the ladder using a ruler.
  5. Fixing a Small Animal Cage Ladder: Schritt 5, Bild 1 von 1
    • Begin pushing rope through the individual holes in the wood pieces (use a sewing kit if necessary).
    • If there is the need to use a sewing kit to drag the rope through the wood here is how to do so: Push the needle through the end of the rope and tie a knot around the rope. Once you are finished with this, push the needle through the rope holes and then sew the rope through the individual pieces.
  6. Fixing a Small Animal Cage Ladder: Schritt 6, Bild 1 von 1
    • Once all the rope has connected the wood into a ladder, tie knots at each end to keep the pieces together.
  7. Fixing a Small Animal Cage Ladder: Schritt 7, Bild 1 von 1
    • Add clips to the ends of the rope and attach to the small animal cage.
    • If the clips cannot attach to the rope, tie the rope around the clips.
Abschluss
Katrina Hartmann
145 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 319
