Zum Hauptinhalt wechseln
Fixing the Error Code 165-6596
Was du brauchst
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: Schritt 1, Bild 1 von 2 Fixing the Error Code 165-6596, Removing the stylus and battery lid: Schritt 1, Bild 2 von 2
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: Schritt 2, Bild 1 von 1
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: Schritt 3, Bild 1 von 1
    • Use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: Schritt 4, Bild 1 von 1
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
Abschluss
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part. Hope you can play a match of Splato- I mean, I hope you can play your amiibo compatible game again!
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 67
Insgesamt: 736
