Zum Hauptinhalt wechseln
Fleetwood Monarch 62" Recurve Bow String Replacement
Was du brauchst
  1. Fleetwood Monarch 62" Recurve Bow String Replacement, String: Schritt 1, Bild 1 von 1
    • Remove the broken or damaged bow string.
  2. Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 2, Bild 1 von 1
    • One end of the new bowstring will have a loop with a larger diameter than the other. Take the larger loop and secure it onto one end of the bow.
  3. Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 3, Bild 1 von 1
    • Slide the larger loop halfway down the limb of the bow.
  4. Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 4, Bild 1 von 1
    • Secure the smaller loop onto the other end of the bow.
  5. Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 5, Bild 1 von 3 Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 5, Bild 2 von 3 Fleetwood Monarch 62" Recurve Bow String Replacement: Schritt 5, Bild 3 von 3
    • Place your left leg between the bow shaft and the bow string.
    • Place your foot behind the end of the bow touching the ground.
    • Place one hand near the middle of the bow and the other hand on the string, close to the larger loop.
    • Push down on the top end of the bow and slide the larger loop into place.
Abschluss
Enjoy your new bow-string!
Eine weitere Person hat diese Anleitung absolviert.
Zachery Kail
121 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 43
Insgesamt: 1,310
