Zum Hauptinhalt wechseln
Einleitung
If the casing of your device becomes damaged and needs replaced we have provided you helpful guides to do so. This should be an easy fix and with just a few tools the casing will be removed!
Ersatzteile
Keine Ersatzteile angegeben.
  1. With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear. With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
    • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
    • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting. Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
    • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
    • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 401
