Zum Hauptinhalt wechseln
Flip MinoHD USB Port Replacement
Was du brauchst
  1. Flip MinoHD USB Port Replacement, Battery: Schritt 1, Bild 1 von 2 Flip MinoHD USB Port Replacement, Battery: Schritt 1, Bild 2 von 2
    • With the Phillips screwdriver 000, unscrew the two small screws securing the battery to the outer case and set safely aside.
    • With the plastic opening tool, pry the battery out of device and set aside. Now the battery is fully removed.
  2. Flip MinoHD USB Port Replacement, USB Port: Schritt 2, Bild 1 von 3 Flip MinoHD USB Port Replacement, USB Port: Schritt 2, Bild 2 von 3 Flip MinoHD USB Port Replacement, USB Port: Schritt 2, Bild 3 von 3
    • Using Phillips screwdriver 000, unscrew the 4 screws from the outer casing. Now the small white microphone should disconnect and is free to be set aside.
    • With Phillips screwdriver 000, unscrew the 3 screws which secure the aluminum USB bracket.
    • Using tweezers, remove the USB port from the device. Your device is now a skeleton and is ready for replacement. To do so, follow these steps backwards.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 494
