Einleitung
This Flip Ultra HD had numerous faults. It is well used and needs a bit of work. This repair is straight forward and does not require a lot of tools.
Was du brauchst
Here is the Flip Ultra HD and it shows lots of use.
The USB latch does not return to the upright position when the USB arm is retracted.
Slide the battery latch to unlock
Slide the front panel down and up to remove.
Remove the battery by pulling up on the tab
Peel the identification sticker back about half way.
Beneath the sticker is a rectangular opening that houses the spring for the USB latch return. In this case it is clearly broken
Use a pair of Needle Nose Pliers to remove and replace the spring
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
