Einleitung
This guide will show you how to replace the camera lens of your Flip Video.
Was du brauchst
Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
Open battery door. This can be done by gently depressing and sliding the battery down downward.
Use the spudger to separate outer shells.
The spudger must be inserted between the shell halves to pry the edges apart.
Slowly work around the outside to separate the halves.
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
Slide out the battery contacts.
Battery contacts
Slot where battery contacts were located
With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
Flip over circuit board so the ribbon connector is facing up.
Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
