Einleitung
This replacement guide will walk you through on how to remove the camera lens. The tools needed are the Phillips #1 Screwdriver and Tweezers. It should roughly take about 15 minutes.
Was du brauchst
Unlock the battery cover by sliding the switch to the unlock position.
Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
