Zum Hauptinhalt wechseln
Flip Video Ultra Circuit Board Replacement
Was du brauchst
  1. Flip Video Ultra Circuit Board Replacement, Circuit Board: Schritt 1, Bild 1 von 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the batteries
  4. Flip Video Ultra Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Circuit Board Replacement: Schritt 5, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Circuit Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Circuit Board Replacement: Schritt 7, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 7, Bild 2 von 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Circuit Board Replacement: Schritt 8, Bild 1 von 1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Circuit Board Replacement: Schritt 9, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Circuit Board Replacement: Schritt 10, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Circuit Board Replacement: Schritt 11, Bild 1 von 1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Circuit Board Replacement: Schritt 12, Bild 1 von 3 Flip Video Ultra Circuit Board Replacement: Schritt 12, Bild 2 von 3 Flip Video Ultra Circuit Board Replacement: Schritt 12, Bild 3 von 3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Circuit Board Replacement: Schritt 13, Bild 1 von 1
    • Unscrew the camera housing unit from the plastic case.
  14. Flip Video Ultra Circuit Board Replacement: Schritt 14, Bild 1 von 3 Flip Video Ultra Circuit Board Replacement: Schritt 14, Bild 2 von 3 Flip Video Ultra Circuit Board Replacement: Schritt 14, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With tweezers, remove the microphone and USB connections.
  15. Flip Video Ultra Circuit Board Replacement: Schritt 15, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 15, Bild 2 von 2
    • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
  16. Flip Video Ultra Circuit Board Replacement: Schritt 16, Bild 1 von 2 Flip Video Ultra Circuit Board Replacement: Schritt 16, Bild 2 von 2
    • Remove the single 2.1 mm screw and separate camera from the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nathaniel Ruf
514 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-7, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 689
