Einleitung
This guide will walk you through on how to remove the power button and replace it. You will need the iFixit Opening Tool and the Phillips #1 Screwdriver. It should take no more than 15 minutes, if it takes more than that then you may have done something wrong.
Was du brauchst
Unlock the battery cover by sliding the switch to the unlock position.
Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
