Einleitung
This guide will help you replace the USB spring should it need replacement. The only tool needed is the Phillips #1 Screwdriver. It should only take 10 minutes.
Was du brauchst
Unlock the battery cover by sliding the switch to the unlock position.
Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
Fast fertig!
Abschluss
