Einleitung
This guide will walk you through how to remove and replace the USB connector should your device be broken or malfunctioning.
Was du brauchst
Unlock the battery cover by sliding the switch to the unlock position.
Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
Gently lift the usb connector using the Plastic opening tool.
Using tweezers, remove the cord from the motherboard by gently lifting the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
My USB port broke off so is there anyway I could save my videos that where om there
Where do you purchase the replacement usb connector?
