Einleitung
This guide will demonstrate how to fix the line strap on a flip-flop.
In Florida, most people own at least one pair of flip-flops. It’s a shoe that is worn almost anywhere; however, between the rainy weather and natural wear and tear of everyday use, one of the most common parts of a flip-flop destined to break is the line strap of the toe piece (between the big and second toe).
Why is this guide necessary?
This guide is necessary because discarded flip-flops are negatively impacting the environment – specifically the ocean.
In fact, dozens upon dozens of flip-flops wash ashore each year. Flip-flops that find their way into the ocean are hazardous, cause pollution, and interrupt the natural habitat of sea animals. Rather than continuously throw away something so common, we should seek to fix it to help support the environment.
Who will benefit from this guide?
This guide will be beneficial for all genders and ages and even for people in different states and countries. Unfortunately, thousands of people around the globe don’t have access to the resources we have here in the United States. A great way to support our planet and conserve resources is to fix our broken flip-flops and donate them to less-developed countries.
Where can I donate my flip-flops?
You can donate your flip-flops to a local charity organization, such as the Salvation Army or the American Red Cross.
Werkzeuge
Ersatzteile
Use the utility scissors to remove the tip of the broken line strap.
Position one 8-inch zip tie underneath the strap line.
Head end of the zip tie.
Tail end of the zip tie.
Pass the metal flat washer through the second 8-inch zip tie.
4.8mm metal flat washer.
Return the tail end back through the hole.
Pass the tail end into the 4.8mm metal flat washer.
Adjust the length of the zip tie to create a snug fit between your toes.
Push the loop of the tail into the hole.
Pull on the tail end until you're satisfied with the length.
Turn the flip-flip over occasionally to check the length of the toe piece as needed.
Length of toe piece.
Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
4 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
