Einleitung
Use this guide to remove the Fox Shocks Float RP2 Propedal.
Was du brauchst
Open the upper damper bolt using a 6mm allen key.
Remove the damper bolt.
Open the lower damper bolt using a 6mm allen key and a wrench.
Remove the damper bolt and lift out the Float RP2 Propedal damper.
Fast fertig!
To reassemble your bike, follow these instructions in reverse order.
Abschluss
