Zum Hauptinhalt wechseln
FlySky FS-TH9X Antenna Wire Disconnected
Was du brauchst
  1. FlySky FS-TH9X Antenna Wire Disconnected, FlySky FS-TH9X Antenna Wire Disconnected: Schritt 1, Bild 1 von 1
    • On the back of the remote, locate the antenna box labeled in red.
  2. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 2, Bild 1 von 1
    • Unplug the wire that connects the antenna box to the controller.
  3. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 3, Bild 1 von 1
    • On either side of the box, squeeze the clips and pull up to release the antenna box away from its socket.
  4. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 4, Bild 1 von 1
    • Unscrew the two 2.5 mm Phillips #1 screws with a screwdriver and carefully remove the front plate.
  5. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 5, Bild 1 von 1
    • Once you remove it, you will see a wire that is connected to the antenna, and a motherboard.
  6. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 6, Bild 1 von 1
    • Locate the brass colored socket and the end of the wire and carefully connect them together.
    • It should click together.
  7. FlySky FS-TH9X Antenna Wire Disconnected: Schritt 7, Bild 1 von 1
    • Once connected assemble the box back together.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 94
