Zum Hauptinhalt wechseln
FlySky FS-TH9X Joystick Replacement
Was du brauchst
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: Schritt 1, Bild 1 von 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: Schritt 2, Bild 1 von 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: Schritt 3, Bild 1 von 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: Schritt 4, Bild 1 von 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: Schritt 5, Bild 1 von 1
  6. FlySky FS-TH9X Joystick Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: Schritt 7, Bild 1 von 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 94
