Einleitung
Often with controls, the joystick that controls most movement can become loose or too tight. This is adjustable by design.
Was du brauchst
On the back of the remote, you will see 6 5mm Phillips #2 head screws.
Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
Referring to dissasembally guide open the remote to expose the inside
Once opened, locate the resistance plate that is highlighted
Fast fertig!
Ziellinie
