Zum Hauptinhalt wechseln
Foldable Grocery Cart Wheels Replacement
Was du brauchst
  1. Foldable Grocery Cart Wheels Replacement, Wheels: Schritt 1, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement, Wheels: Schritt 1, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement, Wheels: Schritt 1, Bild 3 von 3
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: Schritt 2, Bild 1 von 2 Foldable Grocery Cart Wheels Replacement: Schritt 2, Bild 2 von 2
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: Schritt 3, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 3, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 3, Bild 3 von 3
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: Schritt 4, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 4, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 4, Bild 3 von 3
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: Schritt 5, Bild 1 von 2 Foldable Grocery Cart Wheels Replacement: Schritt 5, Bild 2 von 2
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: Schritt 6, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 6, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 6, Bild 3 von 3
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: Schritt 7, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 7, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 7, Bild 3 von 3
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: Schritt 8, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 8, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 8, Bild 3 von 3
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: Schritt 9, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 9, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 9, Bild 3 von 3
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: Schritt 10, Bild 1 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 10, Bild 2 von 3 Foldable Grocery Cart Wheels Replacement: Schritt 10, Bild 3 von 3
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S2-G1, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G1, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G1
1 Mitglied
3 Anleitungen geschrieben
Ein Kommentar
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 66
Letzte 30 Tage: 309
Insgesamt: 8,468
