Zum Hauptinhalt wechseln
Ford Focus Door Interior dome light assembly Replacement
Was du brauchst
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: Schritt 1, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: Schritt 1, Bild 2 von 2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: Schritt 2, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: Schritt 3, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement: Schritt 3, Bild 2 von 2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: Schritt 4, Bild 1 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 4, Bild 2 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 4, Bild 3 von 3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: Schritt 5, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: Schritt 6, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement: Schritt 6, Bild 2 von 2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: Schritt 7, Bild 1 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 7, Bild 2 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 7, Bild 3 von 3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: Schritt 8, Bild 1 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 8, Bild 2 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 8, Bild 3 von 3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: Schritt 9, Bild 1 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 9, Bild 2 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 9, Bild 3 von 3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: Schritt 10, Bild 1 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 10, Bild 2 von 3 Ford Focus Door Interior dome light assembly Replacement: Schritt 10, Bild 3 von 3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: Schritt 11, Bild 1 von 2 Ford Focus Door Interior dome light assembly Replacement: Schritt 11, Bild 2 von 2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cassidy
241 Reputation
1 Anleitung geschrieben
Michigan Tech, Team 1-11, Lauer Spring 2016 Mitglied von Michigan Tech, Team 1-11, Lauer Spring 2016
MTU-LAUER-S16S1G11
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 35
Letzte 30 Tage: 70
Insgesamt: 23,017
