Einleitung
The inside part of the interior dome light assembly is cracked.
Was du brauchst
Remove the screw cover in the handle housing using a flathead screwdriver.
Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
Remove the cover on the door grip by prying gently with a flathead screwdriver.
Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
Pull the locking rod free from the handle bracket and remove the broken handle bracket.
5 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
