Einleitung
This guide will explain and show how to replace a charging terminal that has stopped working. Replacing it requires the use of a soldering iron and the Spudger. This is a fairly easy replacement guide and should only take around fifteen minutes.
Was du brauchst
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Locate the charging terminal's three prong connectors on the back of the motherboard.
Start melting the solder on each prong connector individually with the soldering iron.
Use the flat end of the spudger to pry the charging terminal away from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
