Einleitung
This repair guide will show you how to replace the battery on a Fossil Q Marshal Gen 2 smartwatch. Be careful not to damage the wiring or the metal connectors on your smartwatch.
Was du brauchst
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
Utilize a spudger to pull the orange connector off of the motherboard.
The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
Taking the flat end of the spudger, pry it up.
The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
Remove battery from plastic housing.
Slip wires through large slot in plastic housing to completely remove.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
13 Kommentare
I have read your awesome guide. This is really helpful.
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
Help! I can’t find a replacement battery.
