Zum Hauptinhalt wechseln
Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement
  1. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 1
    • Pull out the hood release in the driver's footwell to pop open the hood.
  2. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 2, Bild 1 von 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 2, Bild 2 von 2
    • Release the hood latch to lift the hood.
    • To avoid difficulty finding the latch, search near the center of the hood.
  3. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 3, Bild 1 von 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Position hood prop rod into the support hole.
    • Hoods are heavy and the securement of the prop rod is necessary to prevent injury.
  4. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 4, Bild 1 von 1
    • Unlatch the three clips securing the engine air filter cover. (The third clip can't be seen in the photo but is on the other side of the cover.)
    • Be sure to allow the vehicle to cool down before working in the engine bay.
  5. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the air filter cover.
  6. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Remove the filter by simply pulling it out of the filter compartment.
Abschluss
Ahmad Elahi
169 Reputation
1 Anleitung geschrieben
York University, Team S1-G10, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G10, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G10
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 52
Insgesamt: 733
