Zum Hauptinhalt wechseln
Framework Laptop 13 Input Cover Replacement
Was du brauchst
    1. Framework Laptop 13 Input Cover Replacement, Before you begin: Schritt 1, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Before you begin: Schritt 1, Bild 2 von 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Frag FixBot
      Kommentar hinzufügen
    1. Framework Laptop 13 Input Cover Replacement, Loosen the Input Cover screws: Schritt 2, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Loosen the Input Cover screws: Schritt 2, Bild 2 von 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      • The screw will make an audible "clicking" sound once it's fully loosened.
      Frag FixBot
    2. Framework Laptop 13 Input Cover Replacement, Lift the Input Cover: Schritt 3, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Lift the Input Cover: Schritt 3, Bild 2 von 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      Frag FixBot
    3. Framework Laptop 13 Input Cover Replacement, Flip over the Input Cover: Schritt 4, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Flip over the Input Cover: Schritt 4, Bild 2 von 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Frag FixBot
    4. Framework Laptop 13 Input Cover Replacement, Disconnect the Touchpad Cable: Schritt 5, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Disconnect the Touchpad Cable: Schritt 5, Bild 2 von 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Frag FixBot
    5. Framework Laptop 13 Input Cover Replacement, Remove the Input Cover: Schritt 6, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Remove the Input Cover: Schritt 6, Bild 2 von 2
      • Remove the Input Cover.
      Frag FixBot
    1. Framework Laptop 13 Input Cover Replacement, Disassembly complete: Schritt 7, Bild 1 von 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Frag FixBot
    1. Framework Laptop 13 Input Cover Replacement, Check the Touchpad Cable: Schritt 8, Bild 1 von 3 Framework Laptop 13 Input Cover Replacement, Check the Touchpad Cable: Schritt 8, Bild 2 von 3 Framework Laptop 13 Input Cover Replacement, Check the Touchpad Cable: Schritt 8, Bild 3 von 3
      • Before continuing, check the Touchpad Cable's ZIF connector located on the back of the Touchpad:
      • Make sure the white line on the cable is parallel to and adjacent with the socket.
      • If the cable isn't inserted far enough, use the flat end of the Framework Screwdriver to flip up the black latch, reposition the cable, and lock the latch.
      Frag FixBot
    2. Framework Laptop 13 Input Cover Replacement, Position the Input Cover: Schritt 9, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Position the Input Cover: Schritt 9, Bild 2 von 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Frag FixBot
    3. Framework Laptop 13 Input Cover Replacement, Connect the Touchpad Cable: Schritt 10, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Connect the Touchpad Cable: Schritt 10, Bild 2 von 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Frag FixBot
    4. Framework Laptop 13 Input Cover Replacement, Place the Input Cover: Schritt 11, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Place the Input Cover: Schritt 11, Bild 2 von 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Frag FixBot
    5. Framework Laptop 13 Input Cover Replacement: Schritt 12, Bild 1 von 3 Framework Laptop 13 Input Cover Replacement: Schritt 12, Bild 2 von 3 Framework Laptop 13 Input Cover Replacement: Schritt 12, Bild 3 von 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Frag FixBot
    6. Framework Laptop 13 Input Cover Replacement, Tighten the Input Cover screws: Schritt 13, Bild 1 von 2 Framework Laptop 13 Input Cover Replacement, Tighten the Input Cover screws: Schritt 13, Bild 2 von 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Frag FixBot
Abschluss
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
247.590 Reputation
1.203 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 71
Insgesamt: 301
