Zum Hauptinhalt wechseln
Framework Laptop 13 Pre-Built Edition Quick Start Guide
    1. Framework Laptop 13 Pre-Built Edition Quick Start Guide, Unbox your laptop: Schritt 1, Bild 1 von 2 Framework Laptop 13 Pre-Built Edition Quick Start Guide, Unbox your laptop: Schritt 1, Bild 2 von 2
      • Unbox your Framework Laptop and make sure you've received the following items:
      • Framework Laptop chassis with pre-installed Bezel, Memory, Storage, and Input Cover.
      • Expansion Cards
      • Power Adapter
      • Framework Screwdriver
      Frag FixBot
      Kommentar hinzufügen
    2. Framework Laptop 13 Pre-Built Edition Quick Start Guide, Install the Expansion Cards: Schritt 2, Bild 1 von 3 Framework Laptop 13 Pre-Built Edition Quick Start Guide, Install the Expansion Cards: Schritt 2, Bild 2 von 3 Framework Laptop 13 Pre-Built Edition Quick Start Guide, Install the Expansion Cards: Schritt 2, Bild 3 von 3
      • Slide an Expansion Card into an Expansion Card slot.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      • For Expansion Card compatibility, check here.
      • Repeat for the remaining Expansion Cards along that edge.
      Frag FixBot
    3. Framework Laptop 13 Pre-Built Edition Quick Start Guide: Schritt 3, Bild 1 von 2 Framework Laptop 13 Pre-Built Edition Quick Start Guide: Schritt 3, Bild 2 von 2
      • Repeat the previous step for the other row of Expansion Cards.
      Frag FixBot
    4. Framework Laptop 13 Pre-Built Edition Quick Start Guide, Assemble the Framework Power Adapter: Schritt 4, Bild 1 von 3 Framework Laptop 13 Pre-Built Edition Quick Start Guide, Assemble the Framework Power Adapter: Schritt 4, Bild 2 von 3 Framework Laptop 13 Pre-Built Edition Quick Start Guide, Assemble the Framework Power Adapter: Schritt 4, Bild 3 von 3
      • Plug the AC Cable into the Power Adapter.
      • Plug the USB-C Cable into the Power Adapter.
      • You can plug either end of the USB-C cable into the adapter.
      • Plug the AC Cable into a power outlet.
      Frag FixBot
    5. Framework Laptop 13 Pre-Built Edition Quick Start Guide, Plug in the laptop: Schritt 5, Bild 1 von 1
      • Your Framework Laptop ships in shipping mode, where the battery is disabled until you plug the laptop in for the first time.
      • Plug the USB-C Cable into any USB-C port on your laptop.
      Frag FixBot
    6. Framework Laptop 13 Pre-Built Edition Quick Start Guide, Turn on the laptop: Schritt 6, Bild 1 von 1
      • Your Framework Laptop is ready for use! Open the lid and press the power button at the top right corner of the laptop.
      • Follow this guide to check your BIOS.
      • For drivers, firmware, and software updates, check out this page.
      Frag FixBot
Abschluss
If you need help, contact Framework support.
Alex Diaz-Kokaisl
247.590 Reputation
1.203 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 190
