Zum Hauptinhalt wechseln
Framework Laptop 13 Touchpad Replacement
Was du brauchst
    1. Framework Laptop 13 Touchpad Replacement, Before you begin: Schritt 1, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Before you begin: Schritt 1, Bild 2 von 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Frag FixBot
      Kommentar hinzufügen
    1. Framework Laptop 13 Touchpad Replacement, Loosen the Input Cover screws: Schritt 2, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Loosen the Input Cover screws: Schritt 2, Bild 2 von 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      • The screw will make an audible "clicking" sound once it's fully loosened.
      Frag FixBot
    2. Framework Laptop 13 Touchpad Replacement, Lift the Input Cover: Schritt 3, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Lift the Input Cover: Schritt 3, Bild 2 von 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      Frag FixBot
    3. Framework Laptop 13 Touchpad Replacement, Flip over the Input Cover: Schritt 4, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Flip over the Input Cover: Schritt 4, Bild 2 von 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Frag FixBot
    4. Framework Laptop 13 Touchpad Replacement, Disconnect the Touchpad Cable: Schritt 5, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Disconnect the Touchpad Cable: Schritt 5, Bild 2 von 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Frag FixBot
    5. Framework Laptop 13 Touchpad Replacement, Remove the Input Cover: Schritt 6, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Remove the Input Cover: Schritt 6, Bild 2 von 2
      • Remove the Input Cover.
      Frag FixBot
    1. Framework Laptop 13 Touchpad Replacement, Touchpad connector information: Schritt 7, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Touchpad connector information: Schritt 7, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Touchpad connector information: Schritt 7, Bild 3 von 3
      • The next six steps show how to disconnect the three cables that are connected to the touchpad. Use this photo as a reference for where they're located:
      • Fingerprint Reader Cable
      • Keyboard Membrane Cable
      • Keyboard Backlight Cable
      • The replacement touchpad comes with a Touchpad Cable pre‑installed, so you don't have to disconnect it.
      Frag FixBot
    2. Framework Laptop 13 Touchpad Replacement, Disconnect the Fingerprint Reader Cable: Schritt 8, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Disconnect the Fingerprint Reader Cable: Schritt 8, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Fingerprint Reader ZIF connector on the touchpad.
      Frag FixBot
    3. Framework Laptop 13 Touchpad Replacement: Schritt 9, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 9, Bild 2 von 2
      • Use your fingers to lightly grip the Fingerprint Reader Cable and slide it straight out of its socket.
      Frag FixBot
    4. Framework Laptop 13 Touchpad Replacement, Disconnect the keyboard membrane: Schritt 10, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Disconnect the keyboard membrane: Schritt 10, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the keyboard membrane ZIF connector on the touchpad.
      Frag FixBot
    5. Framework Laptop 13 Touchpad Replacement: Schritt 11, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 11, Bild 2 von 2
      • Use your fingers to lightly grip the keyboard membrane cable and slide it straight out of its socket.
      Frag FixBot
    6. Framework Laptop 13 Touchpad Replacement, Disconnect the keyboard backlight cable: Schritt 12, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Disconnect the keyboard backlight cable: Schritt 12, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the keyboard backlight ZIF connector on the touchpad.
      Frag FixBot
    7. Framework Laptop 13 Touchpad Replacement: Schritt 13, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 13, Bild 2 von 2
      • Use your fingers to lightly grip the keyboard backlight cable and slide it straight out of its socket.
      Frag FixBot
    8. Framework Laptop 13 Touchpad Replacement, Remove the touchpad bracket screws: Schritt 14, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Remove the touchpad bracket screws: Schritt 14, Bild 2 von 2
      • Use your Framework Screwdriver to remove the two 1.8 mm‑long Phillips screws securing the touchpad bracket.
      Frag FixBot
    9. Framework Laptop 13 Touchpad Replacement, Remove the touchpad bracket: Schritt 15, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Remove the touchpad bracket: Schritt 15, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Remove the touchpad bracket: Schritt 15, Bild 3 von 3
      • Lift the touchpad bracket towards the top of the Input Cover to release its two metal clips.
      • Remove the touchpad bracket.
      Frag FixBot
    10. Framework Laptop 13 Touchpad Replacement, Remove the touchpad screws: Schritt 16, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Remove the touchpad screws: Schritt 16, Bild 2 von 2
      • Use your Framework Screwdriver to remove the two 1.8 mm‑long Phillips screws securing the touchpad.
      Frag FixBot
    11. Framework Laptop 13 Touchpad Replacement, Remove the touchpad: Schritt 17, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Remove the touchpad: Schritt 17, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Remove the touchpad: Schritt 17, Bild 3 von 3
      • Use your fingers to lift the bottom edge of the touchpad and pull it towards the bottom edge of the Input Cover to release its two metal clips.
      • Remove the touchpad.
      Frag FixBot
    1. Framework Laptop 13 Touchpad Replacement, Disassembly complete: Schritt 18, Bild 1 von 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Frag FixBot
    1. Framework Laptop 13 Touchpad Replacement, Touchpad information: Schritt 19, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Touchpad information: Schritt 19, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Touchpad information: Schritt 19, Bild 3 von 3
      • Your replacement touchpad comes with a protective film that helps center the module during reassembly. Do not remove it until you fully reassemble the laptop.
      • Fold the six plastic tabs over the edge of the Touchpad.
      Frag FixBot
    2. Framework Laptop 13 Touchpad Replacement, Place the touchpad: Schritt 20, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Place the touchpad: Schritt 20, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Place the touchpad: Schritt 20, Bild 3 von 3
      Frag FixBot
    3. Framework Laptop 13 Touchpad Replacement, Install the touchpad screws: Schritt 21, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Install the touchpad screws: Schritt 21, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Install the touchpad screws: Schritt 21, Bild 3 von 3
      • While holding the touchpad in place, use your Framework Screwdriver to install the two 1.8 mm‑long Phillips screws securing the top of the touchpad.
      Frag FixBot
    4. Framework Laptop 13 Touchpad Replacement, Place the touchpad bracket: Schritt 22, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Place the touchpad bracket: Schritt 22, Bild 2 von 2
      • Slide the metal clips on the touchpad bracket into its slots on the Input Cover.
      • Press the bracket flat onto the Input Cover.
      Frag FixBot
    5. Framework Laptop 13 Touchpad Replacement, Install the touchpad bracket screws: Schritt 23, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Install the touchpad bracket screws: Schritt 23, Bild 2 von 2
      • Use your Framework Screwdriver to install the two 1.8 mm‑long Phillips screws securing the touchpad bracket.
      Frag FixBot
    6. Framework Laptop 13 Touchpad Replacement, Connect the keyboard backlight cable: Schritt 24, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Connect the keyboard backlight cable: Schritt 24, Bild 2 von 2
      • Slide the keyboard backlight cable straight into its socket.
      Frag FixBot
    7. Framework Laptop 13 Touchpad Replacement: Schritt 25, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 25, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the keyboard backlight ZIF connector.
      Frag FixBot
    8. Framework Laptop 13 Touchpad Replacement, Connect the keyboard membrane: Schritt 26, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Connect the keyboard membrane: Schritt 26, Bild 2 von 2
      • Slide the keyboard membrane cable straight into its socket.
      Frag FixBot
    9. Framework Laptop 13 Touchpad Replacement: Schritt 27, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 27, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the keyboard membrane ZIF connector.
      Frag FixBot
    10. Framework Laptop 13 Touchpad Replacement, Connect the Fingerprint Reader Cable: Schritt 28, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Connect the Fingerprint Reader Cable: Schritt 28, Bild 2 von 2
      • Slide the Fingerprint Reader Cable straight into its socket.
      Frag FixBot
    11. Framework Laptop 13 Touchpad Replacement: Schritt 29, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement: Schritt 29, Bild 2 von 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Fingerprint Reader Cable ZIF connector.
      Frag FixBot
    1. Framework Laptop 13 Touchpad Replacement, Remove the protective film: Schritt 30, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Remove the protective film: Schritt 30, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Remove the protective film: Schritt 30, Bild 3 von 3
      • Flip over the Input Cover and peel off the Touchpad's protective film.
      • Check if the Touchpad is aligned evenly with the sides and the bottom of the Input Cover. If it's misaligned, remove the Touchpad screws, adjust the Touchpad, and reinstall the screws.
      Frag FixBot
    1. Framework Laptop 13 Touchpad Replacement, Check the Touchpad Cable: Schritt 31, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement, Check the Touchpad Cable: Schritt 31, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement, Check the Touchpad Cable: Schritt 31, Bild 3 von 3
      • Before continuing, check the Touchpad Cable's ZIF connector located on the back of the Touchpad:
      • Make sure the white line on the cable is parallel to and adjacent with the socket.
      • If the cable isn't inserted far enough, use the flat end of the Framework Screwdriver to flip up the black latch, reposition the cable, and lock the latch.
      Frag FixBot
    2. Framework Laptop 13 Touchpad Replacement, Position the Input Cover: Schritt 32, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Position the Input Cover: Schritt 32, Bild 2 von 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Frag FixBot
    3. Framework Laptop 13 Touchpad Replacement, Connect the Touchpad Cable: Schritt 33, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Connect the Touchpad Cable: Schritt 33, Bild 2 von 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Frag FixBot
    4. Framework Laptop 13 Touchpad Replacement, Place the Input Cover: Schritt 34, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Place the Input Cover: Schritt 34, Bild 2 von 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Frag FixBot
    5. Framework Laptop 13 Touchpad Replacement: Schritt 35, Bild 1 von 3 Framework Laptop 13 Touchpad Replacement: Schritt 35, Bild 2 von 3 Framework Laptop 13 Touchpad Replacement: Schritt 35, Bild 3 von 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Frag FixBot
    6. Framework Laptop 13 Touchpad Replacement, Tighten the Input Cover screws: Schritt 36, Bild 1 von 2 Framework Laptop 13 Touchpad Replacement, Tighten the Input Cover screws: Schritt 36, Bild 2 von 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Frag FixBot
Abschluss
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
247.590 Reputation
1.203 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 51
Insgesamt: 320
