Zum Hauptinhalt wechseln
Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement
Was du brauchst
  1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: Schritt 1, Bild 1 von 2 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: Schritt 1, Bild 2 von 2
    • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
    • Remove the wheel from the small steel frame.
  2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: Schritt 2, Bild 1 von 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: Schritt 2, Bild 2 von 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: Schritt 2, Bild 3 von 3
    • Hold the bolt that connects the wheel to the fork with pliers.
    • This keeps the bolt through the wheel from rotating.
    • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
  3. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: Schritt 3, Bild 1 von 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: Schritt 3, Bild 2 von 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: Schritt 3, Bild 3 von 3
    • Flip wheel over and remove the bolt.
    • Remove the castor wheel.
  4. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Obstructing Debris: Schritt 4, Bild 1 von 1
    • Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 14-7, Maness Spring 2013 Mitglied von Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 1,459
