Zum Hauptinhalt wechseln
Free Wheelchair Mission GEN 2 Assembly
Was du brauchst
  1. Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: Schritt 1, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: Schritt 1, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: Schritt 1, Bild 3 von 3
    • Align the crossbar (with the hole in the center) with the screw holes on the bottom of one frame piece.
    • Attach the crossbar to the left frame piece with two [2] frame nuts and bolts.
    • Repeat on the opposite frame piece.
  2. Free Wheelchair Mission GEN 2 Assembly: Schritt 2, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 2, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 2, Bild 3 von 3
    • Align the second crossbar with the holes on the back of the frame.
    • This crossbar has two square holes on either side.
    • Attach the crossbar to the frame using four [4] frame nuts and bolts.
  3. Free Wheelchair Mission GEN 2 Assembly: Schritt 3, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 3, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 3, Bild 3 von 3
    • Align the left (L) frame piece with the brake hole on the left frame piece.
    • Insert and tighten using one [1] brake bolt.
    • Repeat using the right (R) brake with the right frame piece.
  4. Free Wheelchair Mission GEN 2 Assembly: Schritt 4, Bild 1 von 2 Free Wheelchair Mission GEN 2 Assembly: Schritt 4, Bild 2 von 2
    • Slide the ring-shaped piece of one castor bearing onto the axle of one castor.
    • Slide the metal tube piece onto the axle of the castor.
    • Repeat for the second castor.
  5. Free Wheelchair Mission GEN 2 Assembly: Schritt 5, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 5, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 5, Bild 3 von 3
    • Slide another ring shaped bearing piece into the castor hole on the frame.
    • Insert the entire castor piece (castor, ring, and tube) into the opposite side of the hole.
    • Secure the castor and bearing pieces with a castor bolt.
    • Repeat on the opposite side of the frame.
  6. Free Wheelchair Mission GEN 2 Assembly: Schritt 6, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 6, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 6, Bild 3 von 3
    • Insert an axle bolt through the center of a rear wheel.
    • Insert the axle bolt with wheel into the axle hole on the frame.
    • Tighten the axle bolt.
    • Secure the wheel with a bolt on the opposite side of the hole.
    • Repeat on the opposite side of the frame to attach the other wheel.
  7. Free Wheelchair Mission GEN 2 Assembly: Schritt 7, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 7, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 7, Bild 3 von 3
    • Slide each handle into the respective slot on the top of the wheelchair.
    • Adjust the handles up or down to your desired height.
    • Secure the handles in place with one bolt and nut for each side.
  8. Free Wheelchair Mission GEN 2 Assembly: Schritt 8, Bild 1 von 2 Free Wheelchair Mission GEN 2 Assembly: Schritt 8, Bild 2 von 2
    • Insert the remaining crossbar between the handles, and align the holes on both sides.
    • Secure the crossbar with four [4] blue tipped bolts and rubber tipped nuts (two on each side).
  9. Free Wheelchair Mission GEN 2 Assembly: Schritt 9, Bild 1 von 2 Free Wheelchair Mission GEN 2 Assembly: Schritt 9, Bild 2 von 2
    • Orient the plastic seat with the smooth side up.
    • The rear strap can be attached to the seat in one of three positions in order to accommodate for people of different heights.
    • Loop the straps over the bars of the frame on either side.
    • Rotate the wheelchair onto its back side.
    • Secure the seat by tying each strap together.
    • Make sure that the straps are tied tightly so that the seat does not fall off the wheelchair.
  10. Free Wheelchair Mission GEN 2 Assembly: Schritt 10, Bild 1 von 2 Free Wheelchair Mission GEN 2 Assembly: Schritt 10, Bild 2 von 2
    • Reorient the chair so it is upright.
    • Place the seat cushion on top of the plastic seat with the angled side in front.
  11. Free Wheelchair Mission GEN 2 Assembly: Schritt 11, Bild 1 von 1
    • Place the bottom of the backrest against the back of the seat cushion.
    • Loop each strap behind the vertical bars of the frame.
    • Secure the backrest by tying each strap together.
    • Make sure that the straps are tied tightly so that the backrest does not fall off the wheelchair.
  12. Free Wheelchair Mission GEN 2 Assembly: Schritt 12, Bild 1 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 12, Bild 2 von 3 Free Wheelchair Mission GEN 2 Assembly: Schritt 12, Bild 3 von 3
    • Slide a footrest socket over the rail located near the front of the seat.
    • Insert a footrest through the bottom of the footrest socket.
    • Secure the footrest with a bolt above and below the socket.
    • Adjust the footrest socket to your desired height.
    • Align the socket's bolt with the nearest hole in the rail, and tighten the bolt.
    • Repeat this step on the opposite rail.
  13. Free Wheelchair Mission GEN 2 Assembly: Schritt 13, Bild 1 von 1
  14. Free Wheelchair Mission GEN 2 Assembly: Schritt 14, Bild 1 von 1
    • Insert the pump bracket through the lower crossbar.
    • Secure the bracket with a rubber tipped nut.
    • Place the tire pump in the bracket.
Abschluss
To disasemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 14-8, Maness Spring 2013 Mitglied von Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,243
