Einleitung
Use this guide when your Frigidaire electric stove clicks but never heats even though the element, thermostat, and incoming power test good. Replacing the failed control-board relay restores normal bake operation for a fraction of the cost of a new board and only requires basic soldering skills and common tools.
Was du brauchst
Schritt 1 Confirm the relay has failed
Run the bake cycle and listen for rapid relay clicks without any heat from the element.
Jump the control board and power the heater directly to verify the element, thermostat, and supply voltage are good.
Schritt 2 Document wire locations and remove the board
Detach the marked wires and lift the control board clear of the stove chassis.
Schritt 3 Separate the housing from the stove
Remove the screws securing the control board housing to the rear panel of the stove.
Pull the board assembly out of the stove to gain full access.
Schritt 4 Release the circuit board
Depress the small plastic retaining tabs to free the circuit board from its plastic housing.
Schritt 5 Inspect for visible damage
Inspect the underside of the board for burnt solder joints, dark spots, or cracked traces around each relay.
Schritt 6 Identify and source the correct relay
Read the voltage and amperage ratings printed on the failed relay and record its part number.
Schritt 7 Desolder the failed relay
Place the board on a stable surface and heat one relay pin with the desoldering iron until the solder melts.
Trigger the integrated vacuum pump to remove the molten solder from the pin.
Repeat the heat-and-vacuum process on all five pins until the relay lifts free, which usually takes two to three minutes.
Schritt 8 Clean pads and traces
Scrub the exposed pads and surrounding area with a wire brush to remove oxidation and burnt residue.
Schritt 9 Position the new relay
Insert the new relay into the cleared holes, matching the original orientation.
Apply masking tape across the relay body to hold it flush against the board while soldering.
Schritt 10 Solder the new relay
Apply fresh solder to each of the relay pins, forming smooth shiny joints that fully wet the pads.
Schritt 11 Inspect and touch up joints
Inspect every joint; add solder and reflow any connection that did not bond properly.
Make a final pass with the wire brush to clear flux residue and ensure clean contacts.
Schritt 12 Reinstall the board housing
Snap the repaired board back into its plastic housing until all tabs lock.
Secure the housing to the stove with the original screws.
Schritt 13 Reconnect wiring
Reconnect each wire to its original terminal using your photos or the wiring schematic located behind the stove’s back plate.
Schritt 14 Test oven operation
Power up the stove and run the bake cycle to verify the element heats normally without rapid relay clicking.
The stove should now heat normally with a reliable relay controlling bake mode, saving the cost of a full control-board replacement.
