Einleitung
If your Frigidaire FFET1222QS has a dead light bulb, follow this guide to replace it.
A light bulb is a very important and necessary part of a refrigerator. A lack of such an important part can cause unwanted spills and accidents in any environment. Which will be a strain on the individual using the fridge.
As you proceed with this guide ensure you have the appropriate 20 watt refrigerator light bulb type for this fridge.
Also, be cautious when installing the bulb, ensure the fridge is completely switched off before proceeding with any of the steps in the guide.
Was du brauchst
Slowly unscrew the dead bulb in the counterclockwise direction to remove it from the socket.
Plug the fridge back into the wall socket, then check if the light bulb is working.
If the light bulb works, return the latch to its original position using your two hands.
Then slowly connect the latch to cover the new bulb and makes sure it is secured before closing the fridge door.
