Zum Hauptinhalt wechseln
Frigidaire FFHB2750TD6 Water Filter Replacement
  1. Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: Schritt 1, Bild 1 von 2 Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: Schritt 1, Bild 2 von 2
    • On the right inner side of the fridge, you will find the model number.
    • Identifying the correct model number will ensure the proper purchase of the new water filter.
  2. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 2, Bild 1 von 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 2, Bild 2 von 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 2, Bild 3 von 3
    • Click options on the control panel on the front of the left door.
    • Here it will say ice maker is on, click the minus button to turn it off.
    • You will hear a beeping sound to ensure that the ice maker is turned off.
  3. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 3, Bild 1 von 1
    • The water filter is in the upper right corner of the fridge.
  4. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 4, Bild 1 von 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 4, Bild 2 von 3 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 4, Bild 3 von 3
    • To remove the water filter turn it to the right until you feel it detach.
    • Then pull the filter straight out slowly from its slot.
    • Water may drip from the filter upon removal. Putting a towel underneath and removing products from that area will ensure an easy clean-up.
  5. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 5, Bild 1 von 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 5, Bild 2 von 2
    • Once the filter is removed, identify the model number on it.
    • The model number will ensure you buy the correct replacement at the store.
  6. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 6, Bild 1 von 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 6, Bild 2 von 2
    • Upon getting the new filter from the store install it into the fridge.
    • Insert the filter straight into its designated slot.
    • Twist the filter to the right until you feel and hear it click into place.
  7. Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 7, Bild 1 von 2 Frigidaire FFHB2750TD6 Water Filter  Replacement: Schritt 7, Bild 2 von 2
    • To turn the icemaker back on click the options button and hit the minus button, it will beep indicating it is back on.
    • To reset the water filter you hit the down arrow button beneath the options button and go down to "water filter".
    • Press and hold the set button above the minus button on the right side, it will then say "good" next to the water filter.
    • Press options again to return to the main screen.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 27
Letzte 30 Tage: 96
Insgesamt: 4,235
