Zum Hauptinhalt wechseln
Frigidaire Gallery Water Filter Replacement
Was du brauchst
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: Schritt 1, Bild 1 von 1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: Schritt 2, Bild 1 von 2 Frigidaire Gallery Water Filter Replacement: Schritt 2, Bild 2 von 2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: Schritt 3, Bild 1 von 3 Frigidaire Gallery Water Filter Replacement: Schritt 3, Bild 2 von 3 Frigidaire Gallery Water Filter Replacement: Schritt 3, Bild 3 von 3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: Schritt 4, Bild 1 von 1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 28
Letzte 30 Tage: 214
Insgesamt: 5,027
